configure radius tls tcp-user-timeout
configure radius tls tcp-user-timeout [ seconds | default]
Description
This command configures TCP connection timeout globally for all TLS servers.
Syntax Description
tls Specifies Transport Layer Security (TLS).
tcp-user-timeout Specifies the TCP user timeout attribute.
seconds Specifies the timeout in seconds.
default Specifies to use the system default timeout.
Default
Use the system's TCP user timeout setting.
Usage Guidelines
This is not configurable per server.
The following example sets the TCP user timout to 60 seconds.
configure radius tls tcp-user-timeout 60
This command was first available in ExtremeXOS 31.4.
Platform Availability
